Old December 13th 2006, 17:54
aircooled4life aircooled4life is offline
suby tranny?
So I was thinking about my next project, my rusted out 72 1302, and I would really like to do a mid engine WRX, but for a tranny I was wondering if it was possible to convert the stock 5 or 6 speed suby tranny to 2 wheel drive using only the front axles for rear drive. or would it just be easier to use a porsche or some other trans?
any help or guidance would be great.
thanks
Eric
Old December 15th 2006, 05:21
you cna convert a wrx trans to 'fwd' by locking the centre diff output drive or just use a fwd subaru trans..
Old December 18th 2006, 21:05
yeah locking the center diff output drive should work.
thanks. Now I just need to figure out every thing else. as far as clutch and shift linkage.
eric
Old December 21st 2006, 01:56
alt+f4 alt+f4 is offline
the wrx trans is ****ed with the stick directly attached to the trans.
A bit harder to relocate the trans than a cable shifter of even the bug end rod shifter.
