Old December 14th 2006, 07:51
Caster adjustment
Is there a supplier that makes a top strut mount for '74 and later superbeetles (1303) that has slots for and aft to give more or less caster?
I rather not grind or file on the body where the strut mounts rest...
On the bug I already have the caster-plus bushings for the swaybar (Topline), but I really want an adjustable top strut caster mount (mainly for my 412 as it has the same top strut mounts as a late superbeetle )
Old December 14th 2006, 16:42
judgie's Avatar
judgie judgie is offline
only ones i have seen are on the j-sports site, so getting them from japan could cost loads.
cheers rob
Old December 14th 2006, 17:57
Had a Whiteline sway bar on my car that had threaded ends so that caster could be adjusted at the bottom of the strut. I've seen on other makes of cars adjustable sections for the sway bar mounting on the chassis.
Old December 15th 2006, 08:57
Thanks for the suggestion Rob!
@ Steve: I really only want to adjust caster on top of the strut, partly because of the fact that my 412 hasn't got any of the possibilities at the bottom of the strut mounts for carter adjustment like a 1303 has.
Any other suggestions (bolt-on, for sale) very welcome
Tnx,
Old December 15th 2006, 09:52
judgie's Avatar
http://www.rallydesign.co.uk/catalog...cPath=907_1714
somthing like this any good?
cheers rob
Old December 16th 2006, 05:41
That may be a neat solution (and not expensive). Curieus how 'universal' it would turn out to be
Tnx.
Old December 20th 2006, 10:29
Racelook's Avatar
Racelook Racelook is offline
www.racehardware.nl (Guus de Koster) got almost the same as mentioned above.
You can't use the camberbolts of H&R??
Wiebrand
B-Extreme B-Tuning.....
Old December 23rd 2006, 06:44
dirk.Gysbrechts's Avatar
dirk.Gysbrechts dirk.Gysbrechts is offline
Caster
Something like this Walter?
http://sylvielavaud.free.fr/quickSta...nts/fondTR.jpg
Old December 23rd 2006, 10:20
Damn, I think you've found exactly what I wanted Dirk!
Wouldn't GWD have these as well perhaps? as he has quite some of the other known gwd parts
Old December 23rd 2006, 11:48
Bullyboy Bullyboy is offline
Wow they press a $20 ball bushing into a steel plate and charge 230wachamacallits. Wheres Lanner? he can make some of those things i'm sure.
Old December 23rd 2006, 15:07
caster
Walter..these are from Remmele of Boxer-shop in Germany..and yes there they are a little bit cheaper....
Old December 24th 2006, 13:52
What are you saying Dirk?
Are they Remmele parts, offered by Boxer-shop? Price of these is quite steep indeed.
Coudn't find these parts on the remmele site...
I have send an email with the question of these also fit for later type 1303 cars with the 2-bolt (Golf) stuts as I recall there was a difference in the stut openings with the later type. Can't remember if the later openings were smaller or larger
Tnx,
Old December 24th 2006, 15:19
JIMP JIMP is offline
Hello Walter
as Dirk said I think also that they are from the boxer-shop, anyway I bought them from PTP (power tuning parts), ask Oliver Knuff to tell you details
Friendly
JIMP
Old December 24th 2006, 16:08
Ok, thanks!
Tnx also for the PM Dirk
Old January 10th 2007, 09:14
Racelook's Avatar
Make your own wally. Will cost you I guess an 80-90 euro to cut, 20 euro for unibal, and an euro of 20 to press in the uniball.
Wiebrand
p.s. the ones that are posted can not be adjusted.
