Old December 19th 2006, 10:36
monkey monkey is offline
Not really German look question - but 1303 wheel knowledge required
Hey all.
This isn't necessarily a G.L. question, but I'm hoping that some of you guys may have the information that I need.
I'd like to fit a set of Gas burner reps (4 lug) to the wifes 1303 cab. Its got standard brakes and standard struts with lowered springs.
I was thinking about fitting 165/65 s on the front and 185/65on the rear, maybe lowering a bit more all round to reduce the arch - tyre gap.Id like the tyres to sit marginally inside the edge of the fender (and clear it!).
The wheels are 15/5.5/22et.
My question is - would they fit under the front arches without fouling the struts? If not, could I get away with a 5mm or 10mm spacer?
I've looked at the diagrams and tools to help, but I'm hoping that someone might have had some real experience with similar wheels / offsets.
Monkey
Old December 19th 2006, 21:41
volksdragon's Avatar
you should be fine
thats the same size and offset of my 8-spokes.
but i'm running 145-65-15's up front
Old December 20th 2006, 04:17
Great thanks.
Its got 8 spoke copies on it currently, although I'm not sure of their offset.
Should be good.
