Old January 16th 2007, 00:49
Veedub Veedub is offline
Do these work?
http://www.vwinnovations.com/bug.html
The side scoops that go over the air vent beside the rear side windows.Are they and improvement or just a ricer thing?
Old January 16th 2007, 01:18
chug_A_bug's Avatar
hey Vee you would have to make a Hole and run it to the Engine Bay but you could use that to get air in there.
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old January 16th 2007, 01:26
But I got a vent on my sides of my car, near the side rear windows...id have to make the hole bigger?
see?
I thought they just went over those...
Old January 16th 2007, 01:34
zeroaxe zeroaxe is offline
What he means is that the air that comes in there doesnt 'flow' to the engine bay. So inside the engine bay you would have to remove some metal to let the air get in(top left and top right hand corners in engine bay). I am just not sure wether this will be any problems with fumes getting into the car when driving slow in traffic etc I would think so....
Zeroaxe
Old January 16th 2007, 01:36
ohh I thought those vents went to the motor...wow...
you can tell Im still new to VW's
Old March 8th 2007, 18:59
Turbo Haraune2's Avatar
Turbo Haraune2 Turbo Haraune2 is offline
WHAT! why didnt i see this before i made them myself? spendt days and days to make the moulds!
And yes you need to cut the body to get the air into the engine also you need to remove foam stuff that seals the passage.
