Old January 28th 2007, 20:05
flat flat is offline
Type 1 Engine parts
I'm helping a friend liquidate. It's all T1 and all prices US:
ARPM Dry sump pump $100, looks new based on that there is no wear on the gear drive.
Engle Cams $C45 ea. New in box with spec card. W140,VZ25,VZ35,FK89,FK10
Oil sumps, 4" deep. New in Johnnys speed and chrome packaging. $75,
Autocraft 6 bolt valve covers, with vents for superflow heads $120pr, New
Timing puck (replaces pulley, no provisions for belt). 2 piece design, steel hub with aluminum outer. Timing marks are machined in the circumference, and they all are for use with a sand seal. $60 Looks new
Dynosaur valve covers for superflows with vents $200PR, Very clean
Superflow valve covers, new $80 pr. 1 pair is used with welded in vents.
Street eliminator heads, 44x37.5, ported. Used but very clean $400pr
Superflow heads with matchported IDA manifolds. Very clean, maybe new. Stamped ARPM at intake manifold face. 44x37valves, with intake and cover gaskets(new). Cut for 94's, $700pr
Superflow heads (ARPM) with IDA manifolds, intake and cover gaskets. 44x37 valved. Used, but still very clean. $600pr.
I can get pics if you'd like more info about a particular item,
www.vdubengineering.com
