Old February 8th 2007, 05:15
nice stuff, but all in the uk
901 fan rings cut to 260mm £52 each
260mm style type 4 shroud £65
914 case cut for 260mm ring £100
44 cb inlets type 4 £50
1 40mm weber idf -32mm chokes £90
w code 1700 engine £100 - bits missing -the good bits
1.9 wasser £50
944 alloy rear arms only £50 -1985
complete 86/7 944 turbo running gear -steel calipers -no brembo model -wide rear -disc over hub model, with iron front calipers
944 turbo brake master cylinder £65
15 window lhd brasillian bus £3000
03 irs boxes -choice of 2 £75 - come with starters and cv's
1600 at irs box £200
t25 2 litre air cooled box -091 £150
1600cc type 1/2 engine 1973/4 external reg £300 -type 2 case
1985 alloy armed but narrow track hubbed 944 rear end -iron calipers £400
1 944 early front hub £40
brand new 150 amp welder rrp 266 -150
london england 0774 858 2044
Old February 8th 2007, 14:53
zeroaxe zeroaxe is offline
Pantswagen, you got a PM
Zeroaxe
Old February 10th 2007, 18:42
