Old February 12th 2007, 12:13
72YloSB 72YloSB is offline
Spark Plug Choice
Has anyone out there tried the four electrode spark plugs, and had success? I am getting ready for a tune up, then my car will get painted, and I will be ready to hit the road. Any spark plugs that you have had luck with, please let me know
Old February 12th 2007, 17:47
chug_A_bug's Avatar
I have heard that NGK ROCK
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old February 12th 2007, 20:51
EvilAngel's Avatar
Several guys in mexico run them without any trouble. Mostly NKG, as chug said
________________________
Engine: Planning Stage
Transmission: Planning Stage
Old February 18th 2007, 13:14
flat flat is offline
I'm not sure about the 4 electrode plugs, but in general NGK's do rock. I use them in all my cars. In the bug with regular reach threads, use the BR6HS.
www.vdubengineering.com
