Old March 3rd 2007, 15:26
Turbo Outer Bearing Size -n/a Inner Bearing Sizes Please
RIGHT 71 BAY SPINDLE - TURBO HUB AND DISC- BOXSTER 2.7 FRONT CALIPER
-NEED BEARINGS
-CAN I BUY THEM OF THE BAT?
DO I HAVE TO
I WOULD RATHER NOT MAKE SPACERS IF I DIDN'T HAVE TO
-THANKS
Old March 4th 2007, 14:46
flat flat is offline
Only the 944NA (early style with the disk on the back), or the 1986 944T hubs (disk on the back) have the same bearings that match the bus spindle.
The later P-cars use bigger bearings. There isn't a 'magic bearing' that fits the later Porsche hubs on the outside and the Bus spindle on the inside. (Atleast, I haven't found it yet).
The spacing between the bearings is too narrow on the 944 hubs anyway, so you'll have to space under the cups.
www.vdubengineering.com
Old March 6th 2007, 16:08
You Would Need
60 -31.5
50 -19
They Just Dont Exist
