Old March 10th 2007, 05:05
71 bus spindles - turbo hub - boxster front caliper -996 front disc
-now the adaptor i need will need to be,
22mm and 17mm - ish
-ie a 89mm to aradial mount
caliper to spindle hole cetres = 25
spindle flats to caliper holes 17
-see its the hats of the 80mm 996 disc that make it all line up 'bob on'
-although, the caliper is suited to a 26mm disc, and the 996 is 28
-file the pins - scratch pack the pads
-hen when the discs wear, cut them , and fit new pads, gaining another bite of um cherry, ps - this wont work will drilled discs
Old March 10th 2007, 05:11
-ie -easy adaptor!!
Old March 10th 2007, 18:37
Old March 13th 2007, 16:47
i have searched and searched
there is no magic bearing 19.050 - 50.005
or 31.075 - 60.005
but there are 19.050 - 53
and 31.075 to 62
so i shall be getting the hubs cut
-would have had to have done them anyway for the grease seal
-plus hopefully as the 19 - 53 is 22mm wide, i won't need to space them, as
the stock one is 13mm, and you need 8
-plus the rear one is a coule wider too
its good as the hub is stock to the spindle ish, not hanging out, like if i were to space it
75 quid for 4 bearings though!!!
21075 = 19.075 -53.975
15123 = 31.750 - 61.999
Old March 15th 2007, 09:26
see a 09078 is 19.050 = 3/4 to 49.6
-you would have though they would have just make the farking bearing 50.005
-smokers of losenge shaped purple vein
similarily, with the stock type 2 bearing
31.750 -its 59.4
-you would have thought they would just have make the thing 60mm
1. 1/4 inch to 60mm
-when enquiring do you make such a bearing, you are greeted with
'are you from outer space'
farging farg
-end of moan, thats without asking, can you incorporate a 4mm spacer into each cup
-moan over
-so to fit a 951 hub onto a type 2 spindle -64 - 79, you need 3/4 to 50 19.050 too 50
inner is 31.750 = 1.1/4 to 60mm
-you need 4mm spacers under each cup
-some one do it!
