Old March 18th 2007, 23:28
alt+f4 alt+f4 is offline
will 914 side shift work?
I got a lead on couple of 914 side shift trannys for $200ea.
Will the side shift work for a bug swap?
Old March 19th 2007, 09:43
Bug@5speed(US)'s Avatar
Using the Side shifter as the basis for your project can be done. Yes, it will work but it requires more work.. Below are is a highlight of what is needed:
Late 901/911 Nosecone or Bugat5speed
Inner Shift rod from 901
Flip the Diff
Relocate breather
You will also neede the inner shift forks and rods and the side plate.
And since your going thru all that, you might as well give it a tune up.. new seals, and check your syncros..
Basically, you need to convert it to a tail shifter.
There are plenty of folks that may swap with you on the 914 boards, FYI.
VR
PS- As you may know we can help if you need sourcing certain parts or converting..
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old March 19th 2007, 19:02
wait....any body got pictures to compair a 914 tail shift to a 914 side shift??? I am not sure what i saw now since i saw a write up on a cable shift tail shifter 914.
Shifter was on nose cone.
Old February 23rd 2008, 03:17
gimmesomeshelte gimmesomeshelte is offline
Flip the Diff
Relocate breather
VR
Alex,
I also have a 914 tranny for the swap. I have not heard that you need inner shift forks and rods and the side plate. Can you elaborate?
Old February 23rd 2008, 12:43
Slc,
If your 914 is a tail its ok, because its all the same minus the inner shiftrod.
The side shift is quite different from a inner shiftrods perspective as it has some different components.. Pic is worth a lot here..
If you want me to ellaborate, no problem. I have some pics but won't get to it till later or tomorrow..
Take care
Alex Olaverri
Tele: 973 204-5463
Old February 23rd 2008, 14:11
Alex,
I have a tail shift. If you can still put up pictures that would be great.
Old February 23rd 2008, 21:02
Yep.. will do.
The tail just requires the nosecone and inner shift rod.. as well as relocating the breather tube in the back..
See the link for more info.. http://www.germanlook.com/Forums/showthread.php?t=9153
If you still need more pics let me know
Alex Olaverri
Tele: 973 204-5463
