Old April 1st 2007, 20:30
Panelfantastic's Avatar
Question about Evercoat Slicksand...
Re-doing the paint on the front bumper cover of the Jetta. Has a few knicks and scratches in the cover along with a crack or two I've repaired with two part.
Can I use the wonder primer to help fill in the tiny stuff on this flexible part? Do I need to add the flex-additive that is used in finish paint to the primer?
Plan is to just shoot it with some single stage and get it back on the road but it has a few pinholes and rough areas that I would like to be able to block down.
Thanks guys!
Jeff-
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
Old April 1st 2007, 21:28
Sorry Jeff, It's ONLY recomended for metal, aluminum, and wood. Personaly, I use SEM39863 plastic adhesion promoter. Followed by SEM39133(sands easy) flexable bumper primer surfacer. They work great with urethane top coats.
Old April 1st 2007, 22:58
Thanks Wrench. What brand is that? I've been shopping at the local Sherwin Williams and using their base/clear stuff (ultra base I think), not because I'm partial, because they are close.
Jeff-
VKG Bastage child
Old April 2nd 2007, 07:02
yetibone's Avatar
yetibone yetibone is offline
It sticks to fibreglass, and SMC plastic too, but I'm not sure about urethane. I'd talk to somebody local who knows. Ask the folks at a paint store that sells Evercoat products. That's how I found out it won't stick to etch primer, instead of finding out the hard way.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old April 2nd 2007, 11:26
Thanks guys! Its a crap shoot at the paint store, sometimes theres a guy there who knows whats what and sometimes its just an order filler behind the counter .
Jeff-
VKG Bastage child
Old April 2nd 2007, 20:56
Jeff-
SEM Panel... It sticks to urethane bumbers too... Got mine in a rattle can (comes in quarts too) from O'Reillys Auto Parts.
Old August 20th 2009, 22:13
WataBug WataBug is offline
they should had named it evercoat hard coat instead of slick coat. the junk does build up thick but its hard as a rock and the stuff when you mix it. u really dont have time to waste.. i shoot alot of different paint.. my fav is house of kolor or any brand 2k urethane primer. i used evercoat slick sand one time. a whole gallon and i'd never paint with that stuff ever again. it was a nightmare from hell. if your not quick enough your gun will ruin, also u got to have a big tip or you wont be able to spray the stuff. like i said if i was to do it over again i'd stayed with 2k urethane high build primer, those builds up really good at hidin stuff and you can block them easy, n have descent clean up times.
