Go Back   GermanLook Forums > Classifieds > Wanted
Old April 6th 2007, 00:05
zulhilmi zulhilmi is offline
Tranny adapter c/w clutch set
Dear guys,im looking for the parts above to mate the wrx engine to old 4sp tranny.Im from malaysia & seriously looking for the parts to be ship in.
Apart from that, can anyone help for a detail steel work,mounting,wiring,suspension & brakes to convert wrx intl my bug.
help needed,
Zul
Old April 8th 2007, 22:02
any reply out there as i need help?
Old April 9th 2007, 12:49
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Are you trying to mate the WRX engine with your transmission? If so, check out Kennedy engineering or outback motorsports for the adapter/clutch package.
Old April 9th 2007, 23:36
thanks mate...is there any problem after i mate the wrx with original tranny?
1.engine mounting problem? as there is no other mounting other than tranny is it?
2.after installing the engine to beetle body, only the cooling system & wiring to be done right?
3.all the original suspension can remain as original?only upgrade the brake system?
regards,
Zul
Old May 30th 2007, 09:59
Hoghead Hoghead is offline
I am in Thailand and about to "reverse engineer" my Suby to 915 adaptor plate and flywheel.
PM me if you are interested and I can easily make another at the same time.
