Old April 9th 2007, 05:34
928 -front hubs
now i am aware that they changed at about 1985
-cos the bearings listed would suggest they had a bolt to back disc
-then 85 on, they changed hubs
-now, they dont look like a 944 hub -a 951 one
so, assuming that a 928 had double a arm front suspension, what are the chances of the hubs being narrower to the face than a 944 -951 one?
-i need about 6mm, so i can run a boxster 's' disc
-plus i like the idea of the track being narrower -stock!
what I am doing is
-i am aware that a 944/951 hub runs a disc that is 75mm high -YES
-i know the 928 has a disc thats 80mm high -same as the 964?
-the 5mm there is what i need, for it to fit better to a type 2 spindle
-or is it the same as the mo30 -944?
-or the 968?
-do they actually look differenmt than a 944 s2?
-i think they look a little longer - at the snout
