Old April 22nd 2007, 21:00
Walrus Walrus is offline
Brake upgrades for type 3's?
What options are available for bigger brakes on a type 3, Im going to be putting Porsche 5 lug wheels on. Can I put porsche brakes? I have a 70 fastback
Old April 22nd 2007, 22:08
This subject has been covered on here in the past. Do a search for "type 3 brakes", or something like that, in the brakes section. You might want to check out the best offset, and how wide of wheel you can fit under those T3 fenders also. The search feature on here is you're friend
Old April 23rd 2007, 09:31
A quick upgrade is Type 72 and later callipers, you'll need to change the stub axles as well.
Old April 23rd 2007, 15:44
badassbug badassbug is offline
just sell your car you'll be better off prolly won't get much for it though
1972 greddy turbocharged superbeetle
Old August 24th 2007, 16:04
notch11's Avatar
notch11 notch11 is offline
I'm putting 993 brakes on my notch.....using 924 front hubs modified to fit t-3 spindle with custom brackets for the calipers anmd the rear i'm using 944t aluminum trailing arms the 993 stuff bolts right to it
