Old April 29th 2007, 15:29
Turbo Haraune2's Avatar
Turbo Haraune2 Turbo Haraune2 is offline
I rest my tools.....
My 1302GT racer is finaly ready!
What a happy feeling to take it for a spinn for the very first time.
Im still on only 0,7 bar turbo pressure but its flying! what wil happen when it reaches 1 bar!? time wil show...
Old April 29th 2007, 17:37
chug_A_bug's Avatar
NEED ALL PIC PLEASE
thanks
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old May 2nd 2007, 05:47
http://v-dubs.no/haraune/album17
First few pic`s of the car
Old May 2nd 2007, 07:56
Rob's Avatar
Rob Rob is offline
*very* nice !
Well done.
Rob.
Old May 2nd 2007, 08:45
Bug@5speed(US)'s Avatar
Very Nice project..
Can you tell us about your roll cage, I like the way its integrated into the front strut towers..
Also is the whale tale a custom rear lid? Did it come from Australia, or did you combine a porsche lid and a VW to make this?
VR
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old May 2nd 2007, 09:11
Chris Percival's Avatar
Cool, very nice, whats the colour?
Old May 5th 2007, 11:02
Bogara_ZO's Avatar
it's a real beauty:agree:
Old May 6th 2007, 16:34
Uncomplete list of modifications:
Body:
De chromed
De badged
De seemed
Fully welded (all body joints)
New all standar rust parts.
Audi A6 doorhandles
Hidden door hinges
Fibegrlass hood and side wings 5+9 cm wider
Alu instrument cluster
Alu inner doorskins+rear
Alu mirror+doorknobs
Replaced inner rear wings with alu frame
Porsche wing with IC(original rear lid, fiberglass wing and Porsche rubber trim.
Flush sidemarkers front
Flush diode sidmarkers on mirrors
Hidden 3rd brakelight under rear window
"Clear" front and rear headlights
Radiator front mounted
Hand shaped ait intake in front apron
Hand shaped ss trim over exhaust
Custom air intake on C-pilars (self made)((yes i have the mould))
Rollcage is home made from prebendt seemless low carbon steel. after FIA regulations. 10 anchor points including front struts. Welded and bolted to body.
Seats and seatbelts from Sabelt. FIA approved.
Much more wich i cant remember
Suspension:
Self constructed unibal rear arms
Cup stag
19mm rear stabilizer
Gaz rear coilovers adjustable. 500lbs springs
Lowering springs front. yellow koni shorter than std.
Double front stabilizer
All urethane bushes where not unibal
Koni adj steering damper. (custom fitted)
Kercher brake kit with rear discs and Porshe boxter front
Cross drilled and sliced brake discs (center vented)
Porsche Cup2 wheels 7+9" (original porshe)
205/50/17 and 245/40/17
Titan wheel bolts.
All hardware is Aircraft standar NAS.
Engine:
Subaru EJ20 Turbo IC 16V Quad cam
Samco air hoses
Saab 9000 IC
Opel omega3000 radiator and fuel pump
Custom alu swirvl tank mounted under original.
Boost 12 psi
Custom SS exhaust system 2,5"
5Zigen mufflers
Trans:
Original Singel cover
Splined gears
Welded 3+4 gear
All trics in the book performed.
Yes it wil break!
Mounted 2" forward,
Much more wich a cant remember and dont want to.
Build time: 4 years and angry wife.
Thanks for comments.
Old May 6th 2007, 16:36
Colour is also home made. Secret code
Crysler has a similar color with less effects in
Old May 7th 2007, 02:47
zeroaxe zeroaxe is offline
Well, you can name more or less mods if you want/dont want to..., it still is a sweet car you have there! Congrats! I love some of the ideas that I might just 'use'
Good work!:agree:
Zeroaxe
Old May 14th 2007, 18:36
Added more pics to my albums.
Car has run 150km now and its time to jack it up and do a torque check to all bolts and nuts. and tighten wheelbearings.
Current top speed:170kmh.and still accel.hard! then it got to scary and i braked.
Old May 14th 2007, 19:43
DORIGTT's Avatar
DORIGTT DORIGTT is offline
What was scary?
Was it the high-speed handling characteristics?
Old May 14th 2007, 23:42
yellow73's Avatar
yellow73 yellow73 is offline
That is a really good looking car. I really like the details and upgrades, awesome job!!!!!
73 Type 1 - 2270 Type IV
64 Type 34 - 1500 Type III
Old May 17th 2007, 18:41
Scary? Narrow norwegian backroad getting smaller an narrower as speed increases....
High speed handling= going straight as a lazerbeam.
Originally Posted by DORIGTT View Post
What was scary?
Old July 4th 2007, 14:22
About three weeks after posting this I found out my engine was running on 3 cyl.
Can you imagine the insane power boost when i replaced one faulty coil??
Had it on a dyno test bed recently and it delivered 244Hp and 315Nm at the rear wheels!!!!! :agree:
I just cant belive how the gearbox stil holds.
