Old May 8th 2007, 06:32
redhot redhot is offline
Centering rings for wheels
Hi,
Do anyone know of this combination:
65,1 outer, 57,1mm inner diameter. Any shops in Germany/US that I should send a mail to?
regards
Jorgen
Old May 9th 2007, 07:38
And does anyone know the correct term for this in german/english?
Its the rings that centers the rim on the hub, for those wheels that come with an oversize bore to accept many different types of hubs.
Old May 9th 2007, 11:15
So, you have a "hubcentric" wheel that you want to bolt on a hub of a smaller size?
Old May 9th 2007, 11:56
Not familiar with the term hubcentric...
It helps centering the wheels when mounting them on the hub. One can do without them normally, if care is taken when mounting the lugs themselves would center.
Old May 9th 2007, 21:16
That is what "hubcentric" means. So you get a more centered (balanced) wheel.
