Old May 10th 2007, 08:47
Jim's Avatar
Jim Jim is offline
Lightbulb Maxx Strut In Porsche Spindle?
Hello quys,
Quick question..
I have a 1303sb 2bolt strut.
Is it possible to bolt without any modification the Maxx strut in '86 944 porsche spindle??
I'm wondering because a friend of mine was trying to bolt '87 944 spindle but he had a problem with the 2 bolting screws.
Kind regards,
Jimmy
http://www.bugaru.gr
EJ20 Suby Naturally Aspirated
Old May 10th 2007, 10:11
Bug@5speed(US)'s Avatar
If your using the early spindles yes you can bolt up to the struts without a problem, but keep in mind that due to the design of the 944 spindle you will find your self needing more negative camber.. Few ways to obtain, topline bolts for the control arm, crash/camber bolts, or slotting the maxx struts..
Now to your incompatibility question.. without seeing your spindles I am guessing you have the later ones, these are somewhat narrower than the older ones if memory serves me right.. Found this out the hard way.. I believe this is your incompatibility issue. Only safe fix was to get the early (pre 85ish) spindles to mate to your maxx struts.. I know there are posts on here regarding the different designs and years..
VR
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old May 15th 2007, 14:01
Jim's Avatar
Jim Jim is offline
Alex,
finally I'was very lucky because I have the pre 86 spindle and brakes from
944 Porsche and after a quick try it fits perfect!!
I have also the hole for the speedometer!!
Thanks very much for your help!
Cu!
