Old May 30th 2007, 12:28
GunnyOz's Avatar
GunnyOz GunnyOz is offline
Carb Help Needed
I live in Hudson County NJ and I'm looking for someone in my area that knows how to set up a Weber Progressive Carb. It's been on my car for 1 year and has never worked right (boggs down low and no better top end than stock) I had the carb installed by a local shop and I've taken it back to them at least 3 times. I'm at the point where I'm thinking about going stock
again.......... Help
Stan
GunnyOz
Old May 31st 2007, 13:54
Bullyboy Bullyboy is offline
honestly I don't know anyone who has successfully used a weber progressive.
One of my friends spent countless hours try to make one work on his, and his brothers engine. Mucho dollars spent= no further ahead.
They both ended up much happier running dual 34 ICT kits.
Old May 31st 2007, 19:46
GunnyOz's Avatar
Bullyboy
Thanks for the info ,my buddies gonna be pissed ,I talked him into getting
this thing. I'm running dual Kad 40's.
Old May 31st 2007, 20:08
should have talked him into something simple like Kads
Old July 9th 2007, 23:58
speedy's Avatar
speedy speedy is offline
you could try setting them yourself using the aircooled.net tech articals i did and it worked out ok
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
