Old May 30th 2007, 14:58
Brodersen Brodersen is offline
914 trans codes.
Hi.. can somebody help me with this code:914 301 30L 03 ..is it from a 1,7 or 2liter.
Thanks bjarne
denmark
Old August 21st 2008, 02:43
C4 Metal Werks C4 Metal Werks is offline
I found a 914 box that I want to by but I don't know if it is a 5 speed or proper for the swap. The numbers on the case are 914 301 101 00. Will this work?
Old August 21st 2008, 08:47
Bug@5speed(US)'s Avatar
On the lower rib, there should be another set of number.. something like 901/1 or 912/0 or others.. what combo is listed, as this will give you the right insight to figure out what you have.. assuming the box has not been modified by PO.
The number you listed, is most like the case part number, can't cross check since I am work..
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old August 22nd 2008, 12:58
Well, no luck with the other numbers. They guy with the trans said there are no other numbers. He did mention it was a side shift. My biggest concern is that it is a 5 speed unless those of you with knowledge are aware of something else I should look out for.
