Old December 6th 2002, 00:16
danielzink's Avatar
I think my gearbox is hosed...
I took the motor out of the notch tonight and what do I see ?
A puddle of gear lube in the bottom of the bellhousing. I was definitely gear lube and not engine oil - by the consistency and smell........The input shaft has a TON of play - both side to side and up and down.....
Whaddya think ?
Dan
65 notch 2300cc type4
www.danielzink.com
