Old July 17th 2007, 20:59
jamesbissland jamesbissland is offline
shift rod mod for 914/901
Hi folks
When fitting the 901 style (OEM or Bug@5speed) nose cone to the 914 Tail shift trans, in stead of sourcing and pulling the trans apart to fit the long 901 shift rod, would it be possible to cut the 914 shift rod and weld a straight rod onto the end to fit through the 901 nose cone hole, thus replecating the 901 one?
I would be interested to hear from anyone who has done this
Many thanks in advance,
James
Old July 18th 2007, 07:06
yetibone's Avatar
yetibone yetibone is offline
That's what I did. I used a VW tranny's hockey stick, and a 914/901 with the square cut from it.
Sorry though, I didn't take any pictures.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old July 18th 2007, 14:23
1303R's Avatar
1303R 1303R is offline
standard 914 rod and beetle rod
welded together with a small piece in the middle 40mm? ish. can't say for sure. i did this after hearing from yeti. cheers dude.
Old July 18th 2007, 20:13
Thats awesome!
So you added about 40mm huh?
Thanks so much again,
James
Old July 18th 2007, 21:16
yetibone's Avatar
Originally Posted by jamesbissland View Post
Thats awesome!
James
That's good advise to add some length between the main pieces. I wish I had when I welded mine together. The shift rod and linkage would have been easier to engineer if the transmission's selector shaft were a couple of inches farther into the opening in the floorpan, but mine works well like it is.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old July 19th 2007, 00:41
Thanks for the info!
Does anyone know the length of a standard 901 shift rod?
Cheers
Old July 19th 2007, 12:17
1303R's Avatar
maybe more like 30mm looking at the pic i posted. can just about make out the ruler next to it.
