Old July 20th 2007, 06:46
redhot redhot is offline
Rear lowering: how much is enough
Hi,
I`m wondering how much I should lower my car to achieve a camber of about 1 degree negative. 1 outer spline too much?
Table of lowering vs spring plate angle
http://www.glenn-ring.com/temp/splines.jpg
Pic of its current stance.
http://blogsimages.skynet.be/images_...6813a44bff.jpg
Old July 20th 2007, 12:31
speedy's Avatar
speedy speedy is offline
to be honest, every car is slightly different , my irs setup was 1 spline 25mm and 2.5degrees on one side and 3 degrees on the other but turning the a arm on the spring plate got it back to 1.5 degrees both sides , there is a thread on here about doing this
hope this helps
j
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old July 20th 2007, 12:56
This is a swingaxle setup so that would differ from an IRS setup.
Am aware that no one can give me an exact number, but a rough guideiance woiuld be appreciated.
