Old July 23rd 2007, 21:26
fat_chris fat_chris is offline
Here is my 1303 project
I just got it started, body is my first object, then suspension.
oh and of course my sexy hella smoke tail lamp
Old July 23rd 2007, 21:31
Look's like you have a good starting point. Keep us posted... New projects are always good to see.
Old July 24th 2007, 22:55
I like the checked roof. Keep us updated.
Old August 14th 2007, 21:55
I changed out to disc brakes up front, coil overs. There all the way down, i think it should be low enough.
So far, i've gathered, Bugpack front sway, i converted to 1302 struts (i had the coil overs laying around) I converted to front disc, i have 914 disc for the rear
Anybody with a car this low what did you do to no thve your tie rods sitting on the body?
Old August 15th 2007, 04:40
petevw's Avatar
petevw petevw is offline
Tie rod relocation kit from Bugpack. That's what i used on my '72 super. relocates the tie rod end under the spindle instead of above.
'72 super
'65 bus
'52 split
