Old July 26th 2007, 01:33
063bug's Avatar
063bug 063bug is offline
Exclamation Narrowed front beam sway bar
On my 63 bug I have narrowed my from beam ~1" either side. I have been told that I don't need a sway bar due to the increased strength of the torsion bars.... I'm not so sure.
Is anyone out there running a narrowed beam with a sway bar and if so where did they get it from. Thanks
Old July 26th 2007, 08:06
Narrowed sway bars are available from CB Performance and aircooled.net...:agree:
Kafer_Mike
Old July 26th 2007, 18:58
063bug's Avatar
Thanks Mike
Old July 28th 2007, 05:49
Bruce2 Bruce2 is offline
Those are probably people who drive as if they have their grandmother in the car all the time.
The effect on body roll by chopping the beam that much is trivial. You still need a sway bar.
Old July 31st 2007, 10:19
65Cabby's Avatar
65Cabby 65Cabby is offline
Whiteline also provide narrowed anti roll bars although they are special order.
http://whiteline.com.au/
See 'Loose the lean' in the Tech section.
My beam is narrowed by 2 1/2" and this roll bar firms up the front quite significantly, it's lowered a little and I'm currently running Red Koni's but as it is a little too firm, I'm going to try gas Spax. (when I can get the different lenghts from them between the G616 and G492)
Old July 31st 2007, 17:25
speedy's Avatar
speedy speedy is offline
cabby have you the front swaybar number for a 2" narrowed adjustable beam
cheers
jon
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
