Old July 31st 2007, 20:01
CV joint cooling, idea maybe?
I'm using 930 CVs on my bug. They will be running at around about 15 degrees. I'm using 944 alloy arms so the outer CVs will be buried in the 944 housings. I'm thinking that they could get a bit hot and I had an idea. What if I made a fan to fit to the CV bolts so that air would circulate around the CV as the car moved or am I being paranoid?
