Old August 3rd 2007, 20:13
jamesbissland jamesbissland is offline
944 caliper width
Hi Folks,
If anyone has a spare second and a set of 4 pot 944 calipers sitting around, would they please be able measure the width (looking from above as if mounted on the car) of the caliper?
Also if you have any 4 pot rear calipers too.
Many thanks in advance :agree:
James
Old August 4th 2007, 08:00
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Are you trying to get the max rotor width for that or the total width of the body of the caliper?
Old August 4th 2007, 16:28
Body of the caliper
Old September 13th 2008, 14:21
vwdevotee
This is sort of an old post, so you might not need this anymore, but here goes anyway. Both the front and rear calipers, measured across the widest point, are 159mm. That goes from the outside edge of the PORSCHE script to the back side of the brake line boss.
