Old August 5th 2007, 04:23
Eliasson Eliasson is offline
Engine oil
What type of enginge oil do you use? Mineral or syntetic. What viscosity works best in your area (usual air temperature when you are driving the car).
What is your experience from using different oil types?
I'm trying to figure out what kind of oil is the best for my engine.
I have a 1835 with dual 44 webers and CB performance street eliminator heads.
It would be nice if you could share your experience.
Old August 5th 2007, 10:34
Bug@5speed(US)'s Avatar
Check this forum
http://forums.aircooledtechnology.com/
There is an oil section, hosted by one of the vendors, that will get you tracking in the right direction
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old August 5th 2007, 12:17
thanks for the link
// Eliasson
Old August 5th 2007, 15:25
super vw super vw is offline
I use SHELL Rotella-T 15-40, it has plenty of zink in it to satisfy your cam/flat tapets. Aircooled engines like there vitamins.
Current cars:
-74 Super Beetle
-86 Vanagon Syncro
-64 sunroof bug
-73 thing
Old August 6th 2007, 15:14
I read the data sheet for it and it seems to be an for use in heavy duty diesel engines and also gasoline engines.
How long have you used it? What temperature do you usually use your car?
// Anders
Old September 30th 2007, 11:29
bigbugman bigbugman is offline
be aware the new shell rotella has almost no zinc in it. It had to be reformulated for the 07 diesel engines. Go to aircooled technology forums and go to the oil section to read more
Old October 17th 2007, 00:35
Type4Unleashed Type4Unleashed is offline
Hi everyone, new to posting here, but have looked in once in a while.
The 911 guys have been using Thr Brad Penn Racing Oils for a time with good results, and I've started using it just recently.
There is a 30 wt engine breakin in oil with a little higher Zinc content than the other Penn oils. There is a 20w - 50w, A 50w A 70w for Nitro Methane motors, and couple others, they also have gear oils.
Here's there link:
http://www.bradpennracing.com/
Richard
Old October 17th 2007, 03:36
Typ Vier Typ Vier is offline
Just a thought, how about adding STP oil treatment to the engine oil? It contains a lot of zinc!
Andreas
Old October 29th 2007, 15:12
Zman Zman is offline
Brad Penn
I am using Brad Penn, and it is great oil for the air cooled engines. You can also look over at Aircooledtechnologies. Jake requires Brad Penn in all his kit and build engines now. Several engine builders and many Porsche builders are running Brad Penn now. I just tore down a type 4 engine with 5K miles on it that had run only Brad Penn break in oil and 20/50, engine looks just like it did when I put it together. The cam and cylinders looked brand new. I am a believer in it.
Gary Zimmerman
69 German Looker T4 2270 Raby Kit
Old October 29th 2007, 23:36
Hoghead Hoghead is offline
There is a thread running on this subject on Pelican Parts 911 technical forum right now. Wade through all the pages and decide for yourself, but Brad Penn (sounds like an actor) seems the oil of choice.
http://forums.pelicanparts.com/showthread.php?t=367300
Great stuff if you can get it however for those of us not in the USA, we need to look at other choices.
ACVW engines have a lot in common with bike engines. I use Mobil 1 Delvac in everything I own. Yes this is diesel oil but read this and decide for yourself:
http://www.calsci.com/motorcycleinfo/Oils1.html#Oil
While you are thinking about oil, think about the filter. If you do not have a filter, install one. I use only Purolator Pure 1 filters for the following reasons:
http://www.calsci.com/motorcycleinfo...tml#OilFilters
YMMV
Robert
Old October 30th 2007, 08:17
DORIGTT's Avatar
DORIGTT DORIGTT is offline
I've had a discussion recently with Charles (LN Engineering) about this.
Check out this link http://lnengineering.com/oil.html
Old October 30th 2007, 13:22
Hello Hoghead
You mentioned that it is important with clean oil, I agree.
Here is an alternativ for oilfilter. It is from the hydraulic world, its a return filter for lid mounting on hydraulic tank. But it works very well with car engines.
It has a 10 mikron nominal filtration which is far better than a standard car oil filter. The larger size and filter area compensate the pressure drop increased by the better filtration.
As you see it is quite easy to mount it under the rear fender (I will probably mount some kind of protection plate in front of it).
I bought it from my local Parker store and also the steel braided teflon hoses.
We are a couple of guys who runs the filters both on street and race with good result.
