Old August 5th 2007, 14:09
split_trix split_trix is offline
Is bus box up to job ?
Hi, i'm currently doing a vwrx conversion in my 52 bug and am using a bus box... some people say these boxes cant handle rapid shifts is this true ?
If it is is there anyway of beefing this part up ?
Reason weather to get the box rebuilt with a berg type 1 conversion nosecone or permanetly run the shift rod above the tunnel and run the handbrake some other way ..... make a bit of a feature of the shift rod (chrome it up a bit)
split_trix
Old August 8th 2007, 18:33
speedy's Avatar
speedy speedy is offline
The drag racing crowd, use bus boxes as an upgrade from a type 1 , i do know these are usually "built" boxes , if it shifts fast enough for a drag racer i would imagine it will be ok the road use.
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old August 8th 2007, 18:42
The ratios aren't that good for a street car. When you change to custom ratios to make it streetable the gear sets suffer, they loose strength by way of not having enough teeth and tooth depth. They are certainly stronger than a Type 1 box.
Old September 14th 2007, 02:02
alikatcraig alikatcraig is offline
Berg's have just posted an ad on Samba for their Bus 5 Speed for bug and split bus. May be of interest. I know Doug has raced his prototype bus 5 for the last 2 years without incident. The big motor puts out over 300HP. Looks nice too!
Old September 14th 2007, 12:30
Hi, by what STEVE C says below is there anyway of adjusting this or choosing different gear sets to improve the durability in shifting ?
chris
Old September 21st 2007, 02:03
If you have any questions on the Berg Bus 5 Speed either call Doug at Berg's, or Mike at Rancho (he's testing one in a street car).
Old September 29th 2007, 04:05
Bruce2 Bruce2 is offline
Originally Posted by alikatcraig View Post
... or Mike at Rancho (he's testing one in a street car).
Although Doug said Mike is testing a prototype in a street car, this is not true. Mike is waiting for a pre-production version to test.
Old January 25th 2010, 22:06
verbeekb's Avatar
verbeekb verbeekb is offline
Berg Bus 5
I've only recently heard about the Berg Bus 5. What I like about it is that is strong and that is fits nicely, simple installation compared to a 901/914 or newer Porsche transmission. Gearing may be a costly issue though. It has a hypoid final drive, just like the 930.. Really not a bad transmission ..
1970 917 Poser
1972 Brunette
2004 VW Sedan
2005 VW LT 35 2.5 TDI
www.karrera.net
