Old August 11th 2007, 13:08
KILLERWATT's Avatar
KILLERWATT KILLERWATT is offline
944 conversion to drum spindles?
I'm sorry if this has been covered, but my search was unsuccessful. Is there a way to go to 944 brakes and keep my link pin, drum brake cb drop spindles. Everything I've seen utilizes disc drop spindles.
Old August 11th 2007, 16:45
www.vdubengineering.com This should have what your looking for. Lanner is great to deal with...
Old August 11th 2007, 18:04
KILLERWATT's Avatar
Yeah, I was on there and didn't see anything not utilizing the cb disc spindles. I figured I'd post here before emailing Lanner.
Old August 11th 2007, 21:24
I remember seeing threads on here about that, but there is sooo many porsche brake conversion post's on here it would take a very long time to find the ones for link pin spindles. Lanner can do the adapter brackets using stock spindles, and you supply the 944 hub's, or go "all the way" and use his custom hub's.
Old August 13th 2007, 22:19
flat flat is offline
It's do-able with the drum spindles, but the bearings are different than the disk ones. I've always done the disk ones, but with a little more head-scratching, the drums would also work.
Old August 29th 2007, 20:49
KILLERWATT's Avatar
Do you need the spindles or can I keep them on my car? What's the turn around time and around how much? Thanks.
