Old August 25th 2007, 11:28
judgie's Avatar
judgie judgie is offline
2ltr dyno results
had the 2056cctype4 on the dyno yesterday and made a awsome 145bhp at 6900rpm at the rear wheels with 129ft lb of torque all this from a 30 year old push rod engine.
biggest prob was on the last run the dry sump pump has broke a gear and sheared the drive so starveing the crank of oil, have got all the parts to sort this bar a 3 stage dry sump pump. anyone one know who makes pumps for the type 4 still? type 1 wont fit.
cheers rob
Old August 25th 2007, 15:23
redhot redhot is offline
Specs of engine?
Old August 28th 2007, 06:22
judgie's Avatar
brief spec is 71mm x 96mm type 4
stock crank and rods with arp bolts
je pistons with deves rings
44x38 welded and ported heads with 911 exharst ports
web 86c cam with lightwieght lifters
48mm throttle bodies and a dta ecu
custom header
3 stage dry sump
cheers rob
Old September 19th 2007, 15:53
judgie's Avatar
well i have all the bits to rebuild now
had a new drive shaft made for the oil pump an found a gear.
new set of h beam 2ltr rods
crank grind and polish with all new bearings.
case has been cemical cleaned
should have it all back together and back in this weekend.
cheers rob
Old September 21st 2007, 18:01
Bad bug's Avatar
Bad bug Bad bug is offline
judgie was the crank damaged. Whats the reason for the regrind and polish.
Old September 21st 2007, 18:15
judgie's Avatar
big ends had been scored when the crank was starved of oil but no visable damage to the mains so just had them polished. so theres a freah service for the new shells to bed to.
cheers rob
