Old August 25th 2007, 17:02
Veedub Veedub is offline
Drums in 4-100 bolt pattern
Does anyone know of any other places that sell drums in the 4-100 pattern for a 72 Standard bug ?The only site I found was cip1.
Old August 28th 2007, 15:43
notch11's Avatar
notch11 notch11 is offline
in the U.S. its them or aircoled.net.......and csp
Old August 28th 2007, 20:33
thanks , i forgot all about aircooled.net
edit:i looked on there site an they dont appear to carry them in the 4-100 pattern.
Old August 28th 2007, 21:14
There was a company called Jatech Forge that had blank drums, rotors, and welded dropped spindles. They could drill for a 4x100. I did a google on the name and nothing came up. (this was years ago though)
Old August 28th 2007, 21:22
looks like cip1 is the winner then.Is it safe to get the stock drums drilled for the 4-100, just wondering.
Old August 28th 2007, 21:31
It's been done. I think there's a little extra work on the back side though. As you get closer to the center the casting gets thicker, and you have to counter bore all the holes down to the same depth. (not really all that big a deal)
Old August 28th 2007, 21:46
would the be cheaper to do or round the same as paying 80 bucks a drum, if you know?
Old August 29th 2007, 21:38
I would guess about the same... unless you have a friend that works at a machine shop.
Old August 31st 2007, 19:12
I believe the ones CIP1 sells are modified from stock in that they don't have the rear 5 arm web like stock, they are just thick everywhere so any pattern has a safe thickness of metal to drill into, check it out.
