Old August 29th 2007, 18:06
learner learner is offline
ej22 convertion or ej20t
hi, i'm new at convertion and i am looking at doing the above. is there a step by step way of doing it? what's involved? i have been trying to looking for info but i can't find any that tells me what to do and what to get.
cheers all
this is for a 1969 beetle
Old August 29th 2007, 19:21
davetaylor's Avatar
davetaylor davetaylor is offline
here's a very informative site, although it's for a vanagon.
http://www.weidefamily.net/vanagon/
there's a ton of info there.
be aware that going ej20t will be thousands more, both in buying the engine and building tranny and such to handle the higher power output.
there are lots of other links, but the one i just listed is one i rarely see posted and it's a good one.
1979 'vert w/944 NA brakes + Boxster S wheels and begging for a paint job and a Subie swap
Old August 30th 2007, 12:30
Eatoniashoprat's Avatar
The ej22 is a much simpler swap, you use the same engine adaptor as with the EJ20T. The ej22 requires no major clearancing in the engine bay and you don't need to move the engine/tranny ahead to get it to fit inside the engine bay.
The ej22 puts out around 140hp depending on the year and the ej20t puts out between 200-230 (USDM stock) depending on the year. A friend of mine has the ej22 in a 69 beetle and loves it, still has an enormous amount of power and the tranny doesn't cost a fortune, I've put an ej22 in my 69 van and it works amazing, i've put 35000 miles on it since and not even a hiccup. I'm currently putting an ej20t into my beetle and there is a considerable amount more work to do just to get it to fit. It all depends what you want.
As for whats involved, you need to buy an adaptor plate and flywheel (or get yours modified), you need a transaxle that wil take the torque, find a rad and make some mounts/airducting/piping to move coolant/ fuel tank modifications to move more fuel. If its an ej20 you'll need to get air to the intercooler or use an air-to-water intercooler and mount a coolant pump.
A couple sites:
www.vwrx.com
volks swap
www.naisoc.com for subaru info.
Hope that helps
Mike
1302 EJ20 turbo
