Old August 30th 2007, 03:57
tchaika tchaika is offline
Brakes under link pin, 4x130mm stock wheels
OK so if I want to put discs on my kp/lp ghia and keep standard 4x130mm wheels with stock ride height - are there any options for porsche brakes? From what I have read, the signs aren't good.
Or do I have to go with a custom kit?
Old September 7th 2007, 18:11
flat flat is offline
Yeah,
It's more work then to adapt the Porsche brakes back to 4-130mm bolt pattern. The rear 944 hubs can be machined without much drama, but in the front it would require custom hubs since 944 have no provisions to remachine into a different bolt pattern. Sounds expensive....
www.vdubengineering.com
