Old September 6th 2007, 17:44
chug_A_bug's Avatar
Just wont Start
Hey guys well I think I have Tried everything that I can think of but now looking for Some help.
ok So New 1641cc duel 36mm carbs.
I was just Sitting at a Stop light the Other day and Bam no Warning, nothing it just Quit
so I got it towed home and Started looking at it and I got Fuel but now Spark, put in a New Bosch Blue Coil and Still nothing
what am I Missing? PLease help
thanks
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old September 6th 2007, 20:46
Do you have any electrical power to the car? (lights, horn, radio) If you don't, start at the battery, fuses, and ignition switch. (in that order)
Old September 6th 2007, 22:10
chug_A_bug's Avatar
Hey Ya I have Power to everything and it turns over just Fine
it just Wont make Spark all Fuse's are good. took the tach wire off the Coil
I'm running pionts and they have not Closed
thanks for your time
74 Std. GL
08 Vw rabbit
18 WR250R
Old September 7th 2007, 07:10
petevw's Avatar
petevw petevw is offline
No spark huh?
-When turning the key ON, do you have 12V at the coil?
-Has one of the wires come out of the +ve battery post?
-The plug on the back of ignition switch fully seated?
-The screw that holds down the points on the distributor, tight?
-Are you getting spark from the coil? Bad wire from coil?
-Ground strap from trans to frame horn snapped? loose?
PM me your phone/cell#.
'72 super
'65 bus
'52 split
Old September 7th 2007, 20:58
gonebuggy's Avatar
Alright, heres what you should check:
You've checked to make sure that when you look down the carbs and you pump the linkage you see fuel squirting down?
Checked the plug by grounding it while turning the car over? car turns over, lights work?
So no spark; checked wires? Run a voltmeter across the coil when turned on? all other wires are connected properly? next: check the cap for cracks, checked the contacts inside it? check the little sprung carbon button that touched agaist the center of the rotor? have you checked to see if the points were loose? do they open and close when you turn the motor? Checked the condenser and it's connection, both to the points, and to the coil? has the distributer moved? when open the "number one line" should be roughly the 5 o'clock position.
It may be entirely possible that somone has wired in another fuse in or near the engine bay. Follow all wires from the engine.
If you've done all that, then i'll have to think about it some more lol
best of luck bro,
1970 Bug
2110cc. ???Whp, ???Ft/Lbs
