Old September 14th 2007, 01:41
DominicG DominicG is offline
conversion question
hi all,
im in the process of building a volksrod right now, and want to continue being different by throwing a subaru in back.
i looked through a lot of threads and found alot of info.
but i need one thing made clearer.
what exactly do i need besides the engine????
my bug will be fender-less and have no rear apron, just the deck lid. so fit is not an issue.
also, ive heard of a conversion kit and found a link ( http://www.rjes.com ) but im curious if there are any others??
thanks alot everyone!
Old September 14th 2007, 10:59
Eatoniashoprat's Avatar
Things you need to do this conversion:
-adaptor plate/flywheel
-transaxle to handle the torque
-radiator with electric fans mounted up front w/ adequate ducting
-if its a turbo you need to mount the intercooler some where or go with an air to water unit and use an electric water pump
kennedy engineering makes a kit with adaptor plate and flywheel that a lot of people use
doing a non-turbo would be much easier, an EJ22 non turbo and is between 135-140 hp, and EJ25 non turbo is around 160-170, a EJ20 turbo is between 230-270, and an EJ25 turbo (newer STi engine) is around the 300hp mark. I would suggest the EJ22 because they are widely available and are they least expensive option. all the engines have the same bellhousing so are interchangeable. THe other difficult thing about this swap is the wiring, a lot of the wiring harness can be removed. another option that people do in some dune buggies is ditch the efi and make a mount on the intake for a 4-barrel carb.. on an EJ22 this will put you at around 120hp if its tuned decently.
Not sure if thats completely what you were looking for but hope it helps
1302 EJ20 turbo
Old September 14th 2007, 17:14
this helped a lot, thanks!!!
