Old September 15th 2007, 15:38
hemitheus hemitheus is offline
New twist on the classic "will it fit?"
I have a 74 Standard stock height. IF i go with...
Wheel Size: 17x7
Tire Size: 205/40
Wheel Offset: 42mm
What width wheel spacers would i need to prevent knocking components inside the wheel/tire
and
WHat size widened fenders would i need to fit the wheels?
I have tried the calculator mess but it just doesnt click in my brain.
Also... would i be able to lower the car any without messing this all up? If so how much?
Id appreciate as much help as you guys can give me
Old September 28th 2007, 05:43
Typ Vier Typ Vier is offline
I fitted the GT3 brake to a ball joint front end and had issues with the clearance between the calipers and the 17 inch wheels. Wheels are/were 996 BBS 7x17 50mm offset. I fitted a 2 inch narrowed beam and then added porsche 25 mm (1inch) wheel spacers. This cleared the calipers a little more and also gave more room on the inside of the wheel to the axle beam.
Andreas
