Old September 26th 2007, 16:19
vwbao vwbao is offline
rack and pinion conversion kit available ghia,beetle
hi this is the kit for our ghias and beetle
http://cgi.ebay.de/Zahnstangenlenkun...QQcmdZViewItem
and this is their website, please contact them to join us here in this particular forum. I already emailed them, please do so.
http://www.classic-centrum.de/mitte.htm
Old September 26th 2007, 20:34
The Ebay link doesn't work, what was it?
Old September 27th 2007, 04:38
hi, sorry maybe the item has now removed from ebay. but heres is the picture of it...
Old September 27th 2007, 04:45
hi guys, try this again.
Old September 27th 2007, 10:52
That looks nice, it gets rid of the uneven tie rod length.
Old September 27th 2007, 17:45
Looks pretty well designed, I wonder how the steering geometry is now.
Old September 28th 2007, 14:28
1303C2/3 1303C2/3 is offline
Well finally someone comes up with the r&P steering for the torsion beam front end. I wonder what the steering ratio is. It would be cool to use the original (size) classic bug steering wheel and have an ultra quick steering response. Btw. I was dreaming bout r&p for my type 3 squareback. Because the type 3 framehead being different than the type 1 bug I thought it would be much easier to graft in the r&p type steering box. (or for a Porsche 550 replica)
Something else struck my attention.
http://www.classic-centrum.de/images...ntwicklung.jpg
That's a ''cool'' cooling system for the type 4 using orig. parts.:agree:
Old September 28th 2007, 17:49
here is the english version of the site...
http://translate.google.com/translat...language_tools
Old September 29th 2007, 09:45
GS guy GS guy is offline
I like that set-up too.
Please share the steering ratio!
The rack itself looks like pictures I've seen of the very unusual Passat rack.
Jeff
Old September 30th 2007, 09:30
Jeff
i dont know the ratio, but you can email,fax or call them for more details.
Old October 28th 2007, 06:35
hey! anyone contacted them? any updates? come on guys lets convince them to make more of this stuff so it will be available in the market.
Old October 28th 2007, 07:27
Bao,
You might try researching the Passat and New Beetle steering racks, I believe they use the same design rack as shown in the pictures above (though more likely a power version). You might look for a manual rack conversion for the New Beetle (or maybe even the newer Golf)?
I noticed my Acura RSX also utilizes a center take-off steering rack, though not quite like the above rack. It's also a power rack,
One problem I've found researching R&P adapting is the good old VW steering box, in combination with the stock VW steering geometry and spindles, actually has a pretty quick steering ratio already. Something like 14.5:1. The standard "quick" ratio seems to be what's referred to as the "Corvette" ratio at 16:1. Most modern cars with sporting intentions run around these ratio numbers - but usually with power steering (and most being FWD). I found it difficult to even find a manual rack that would provide a quicker than ~20:1 ratio (with the VW spindles), regardless of original application - that is unless you went with a dedicated race-car steering rack, or one of the off road (Baja bug/sandrail) style racks. The former usually runs in the $500 range (for bare rack), while the latter is difficult to adapt to a VW Beetle without lots of other modifications (like removal of the fuel tank). The elusive combination of inexpensive and easy to adapt may be covered with the rack in your original post.
You said youi tried to email them, ever get a response?
Jeff
Old November 7th 2007, 13:31
tumba tumba is offline
Hi!
I'm pretty sure that the rack comes from an VW Polo 1/2/3 up to 86C model, ie. model years 86-94.
It is also used on the Audi 50 and VW Derby.
/Johan
Old November 20th 2007, 18:46
For anyone interested, they only make LHD. Looks like I'll be fabricating my own at some point I think. Seems pretty straight forward
