Old November 2nd 2007, 12:58
fuzzybear1981 fuzzybear1981 is offline
944 brakes on my 1303s
Hi, i have read your comments on this but am still confussed.
I have my bare pan sitting in my barn...I have front and rear discs inc hubs and calipers from a 2.5l porsche 944....shall i buy the master cylinder as well? Wat was that about the bmw resevoir??? Please i need ur help
Old February 5th 2008, 22:35
V73W's Avatar
V73W V73W is offline
From what I heard and read, if you are using the 4 piston brembo's from a 944 turbo all the way around the stock master cylinder works pretty well, if your using the N/A 944 single piston sliding ATE calipers then you will probably need a larger master cylinder because the stock mc just cannot produce the volume that the large single piston needs. As for the BMW reservoir I don't know anything. You can check out the technical section on www.vdubengineering.com, he has some more info on porsche brakes and on here his name is flat.
