Old November 21st 2007, 14:58
Dark Wanderer Dark Wanderer is offline
944 with different bolt pattern?
Hi!
I would like to know if I can make something to my problem: I want to install 944 brakes in front but I want to keep my 4*100 bolt pattern too. Is there any way to do that or it's just impossible?
Old November 22nd 2007, 00:39
I don't think you can do it unless you use a specially made billet hub, I think Vee Dub Engineering does these. The 944 front hubs are cast with provision for the stock wheel bolts only.
Old December 26th 2007, 10:33
mabbo mabbo is offline
iv been thinking about doin this too but dont know if my idea would work
take a old vw disk and machine the braking surface off,
use this as a hub
use a 944 disk but get it drilled for vw 4 stud pattern
mount hub and disk to car,
caliper bracket and 944 caliper
you should have 944 brakes in vw 4 stud pattern, or, im talking crap?
mabbo
Old December 27th 2007, 03:03
Hi Mabbo
That's what I did with brakes, only I used a Porsche pattern Beetle rotor.
Old January 4th 2008, 20:33
hey steve,
they look really good... but i want to keep 4 stud vw pattern... do you think its possible to re-dril the porker rotor in vw pattern to work with studs on the vw disk/drum (hub)?
mabbo
