Old December 4th 2007, 17:23
Eatoniashoprat's Avatar
Kafer style brace
Hi, I'm planning on buying a 3-bar from vdubeng when my car is ready, but for now I'm wondering how it ties in to the frame horns exactly. Does it have a bent tab that is held on by the frame horn bolts?
Also, is it the aluminum that needs welding once you get it in place or the steel pieces? I know all this would be answered if I just bought the darn things now but right now I just want to know if I need to beef up the tranny cradle and if I'm gonna need to make friends with someone that can weld aluminum.
Mike
1302 EJ20 turbo
Old December 4th 2007, 19:05
Bullyboy Bullyboy is offline
welding is required
The HD cradle is this one
http://www.cip1.ca/ProductDetails.as...C13%2D9543
Old December 5th 2007, 19:49
Hey BullyBoy thanks for the pics. I can see now what I need to see. It looks like it will be better for me to buy the heavy duty cradle rather than beef mine up.
1302 EJ20 turbo
Old December 5th 2007, 20:56
The stock cradle is only half the thickness of HD one.
Old December 30th 2007, 17:35
Bad bug's Avatar
Bad bug Bad bug is offline
Bull boy how did you torque your bar did you pull up on it.
Old December 30th 2007, 20:10
Just hand tight and locked the nuts.
No wheel hop, no matter how hard I've launched it
Old January 1st 2008, 00:22
Here's a tip -- don't weld the tabs to the transaxle cradle until you've installed your header/exhaust. I had to send my driver side j-tube back three times to be re-welded/re-bent to clear the downtube from the brace. Live and learn...
Kafer_Mike
Old January 6th 2008, 16:01
dstar5000 dstar5000 is offline
Hmmm, I like the alu look AND the anodized look. What is the cost of the different ones?
THAT might help me dicide which one I want!
Don
Old January 6th 2008, 16:45
I powder coated mine with eastwood transluscent red.
Mine came from Lanner at VDub Engineering, around $80 cheaper than CSP ones that mike has.
