Old December 6th 2007, 16:39
fuzzybear1981 fuzzybear1981 is offline
18s or 17s???
i am fitting coilovers ot my 1303s , how much will i be able to lower if i have 18s or if i have 17s, cheers
Old December 6th 2007, 21:09
about the same. It will come down to width and offset rather then wheel diameter
Old December 7th 2007, 05:08
I am looking at porsche 911 turbo wheels, i have wide wings on the rear so they will be 10 inch but the fronts are 7.5....what is the biggest off set possible?
Old December 7th 2007, 08:54
skywalker
It depends on what kind of struts you have, with small after market ones you can go for a higher off set.
This is 7J 17" ET55 on a 1303:
