Old December 9th 2007, 06:27
effvee effvee is offline
923 trans
Hi, anyone know of a 923 Porsche trans, I'm told it was the 5 speed with special gearing for the 912? It should look like the 915 not the 901.
Old December 10th 2007, 07:44
yetibone's Avatar
yetibone yetibone is offline
Came in the 1976 912E only.
They are haaaaard to find.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old December 10th 2007, 11:11
Cohibra45's Avatar
Cohibra45 Cohibra45 is offline
I was thinking of going that route with my Ghia, but Jake said that they used one year only bearings and those will be getting extremely hard to find .
FYI
Take care,
Kelly (Cohibra45)
Old December 10th 2007, 13:38
This gearbox also has a 7:31 R&P, same as a 914 box. The 923 is a 915 with a 901 bellhousing so you can use a push clutch setup instead of a pull setup commonly found on a 915.
You can convert the 915 from a pull to push quite easily though
Old December 11th 2007, 07:56
petevw's Avatar
petevw petevw is offline
How much are they worth?
'72 super
'65 bus
'52 split
Old December 11th 2007, 08:11
yetibone's Avatar
A buuuuuuunch of money.
Actually, I don't know. It would depend on the condition I guess. Someone here had one in his 912E and sold it when he replaced the drivetrain with that of a 911. I believe 923 ended up in Shad Laws Type III. This had to be about four years ago or more...
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old December 13th 2007, 15:38
Spec's
Hi everyone, some time ago someone of this site listed a spec sheet for the 911 transmission. But I did not see any informaton on the 923, since the 923 was geared for the type IV, and having its gearing shorter is different than changing the bellhousing to fit a type IV engine. The members name is MX67, also n 7.31 ring & pinion I beleive the 7.31 ritio is fifth gear from the paper on 911 I have. The ring and pinion are in the 4.285 and some 3.875 ration
Old December 20th 2007, 02:07
Hi, I just received a PM from a member on Pelican Parts. The 7:31 and 8:15 are correct ring and pinions, sorry about that sandeep, had it wrong, I was thinking in a manner of regular VWs
Old January 6th 2008, 18:23
Clatter Clatter is offline
I recently came across a 923 on the Samba.
It had been listed for six months or so with no takers.
He wanted $800 for it, and sold it to me for that, but he paid for shipping.
It was a little scary, because the car was in a fire, then the junkyard bent the shift rod taking it out.
It went to my local ace for a go-through, and all checked out well.
THey were able to straighten out the shift rod, and the case didn't get warped from the fire.
It did come to $700(!) for a gasket set and look-through.
Good thing it didn't need any parts!
The scary thing was, if it had been robbed for the close-ratio gears...
A tooth count, along with a cross-reference, showed that it had the correct 1-4, but a closer-ratio 5th from the 2.7 Carrera.
R/P 4.43
1st 3.182
2nd 1.834
3rd 1.261
4th 0.96
5th 0.72
The master said it looked like the box had never been apart,
He was betting that the .072 5th was installed from factory.
Doesn't hurt my feelings, as this is going in a type3 with type4 power.
In digging around, the 923 boxes are out there...
Search 923 or 912E in Google.
There were a couple of different Porsche-specific and 912E-specific that had a used box or two...
While the release type can be easily ironed out, try pricing out those gears
Unless you are going to find a 2.7 Carerra box, maybe....
Old January 6th 2008, 23:51
Cohibra45's Avatar
Clatter,
Glad to see you got the trans from Samba. That is the one I ask Jake about for my Ghia. Like I said earlier, he told me about the 'one off' bearings used for this trans and that is why I decided not to pursue this one.
Glad to see that your trans specialist said it was ok.
Take care and good luck,
Kelly (Cohibra45)
BTW, I am going with the Rancho Trans with the gear ratios and Quaife. !!! Expensive, but not as much as when you mention the 'P' word!!!
Old January 10th 2008, 21:26
Was the "one off" bearing Jake mentioned the throwout?
I noticed that the 923 has it's own throwout, unfortunately.
$245 list price....
Old January 11th 2008, 13:17
Cohibra45's Avatar
Not sure which bearing Jake was talking about. He would be able to help...give him a PM or email.
Good luck with it though !!!
Take care,
Kelly (Cohibra45)
