Old January 2nd 2008, 06:17
vwdevotee
993 Headlamps
Has anyone fit 993 headlamps into SuperBeetle or Ghia fenders? Does anyone know where there are pictures?
Old January 4th 2008, 16:34
speedy's Avatar
speedy speedy is offline
according to remmell , it can be an option on his wings(requires larger buckets ), i have not seen a set though
cheers jon
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old January 5th 2008, 09:30
Ive seen them on early beetle fenders and on a Ghia as well
Old January 5th 2008, 13:43
vwdevotee
Say what? How about a photo of that?
Old January 5th 2008, 20:38
Are they a projector style headlight? If they are they usually hang out the back a long way.
Old January 6th 2008, 01:21
vwdevotee
The 993 had two headlight options:
1. Standard Halogen
2. HID/Litronic
The Litronic is supposed to be a plug and play upgrade, so even the halogen must have been fairly long housings.
Old January 17th 2008, 08:45
karol karol is offline
Thumbs up
I am going to fit some clear H4 lights. Anyone else fitted them and how is was it? Any pics would help. Thanks
Old January 17th 2008, 10:19
siromega's Avatar
siromega siromega is offline
You got me curious now! I'd like to see some pics of those on a beetle.
Old January 17th 2008, 12:16
vwdevotee
I have H4's on my Ghia; they look dead stock (fluted lenses) except that they throw the light to the left side of the road instead of the right. I know I've seen pictures in thesamba.com's photogallery of free form reflector (clear) H4 lamps.
Old January 17th 2008, 17:19
found this on google
http://images.google.gr/imgres?imgur...icial%26sa%3DN
it shows the size a bit
Chris
Aircooled 4ever
1973 1303 going towards GL
Old January 17th 2008, 18:27
I fitted some Hella H4 semi sealed beams to my daily 1303. I used early Mini headlights, these screwed into the existing holes in the Beetle wing/fender/guard
You could do the same with the clear ones. I then cut the adjusting screws from my stock headlight rim and just bolted it back over the light using the stock screw.
Old January 21st 2008, 19:48
thanks hun
Old January 26th 2008, 09:32
Xellex's Avatar
Xellex Xellex is offline
pics of my H4 brasilian 3 chamber clear lights + HID kit, hope it helps
Here you can see the difference between HID and Halogen
Everything was fitted inside the fender headlight bucket.
Old January 26th 2008, 10:00
Xellex - I presume these are LHD ones? I couldn't find ANY in RHD for those of you who may be wanting them in the UK/AUS
Old January 26th 2008, 10:14
Xellex's Avatar
well yes, my car is a LHD, but I don't think the manufacturer of these headlights makes a difference. Everything you can do is adjust them from their screws.
