Old January 12th 2008, 05:40
1303R's Avatar
1303R 1303R is offline
rear suspension bushes
hey, whats the best make poly bushes? i'm fed up of them wearing out very quickly, am i better off using rubber? i'm really tempted to convert to coil overs just to get decent mounting. this is a fast road car, lill less than 200bhp and all the one's i've had are crap. is there an alterative? saw on here brass bushes once, anyone know anything about them? cheers
Old January 12th 2008, 22:08
They make bronze and plastic ones for 944's. I bought some bushings for 944 and VW they measured the same. Pelican parts sells some of the bronze and plastic one's. Look half way down the page of this link, and you will see some "poly bronze" bushings. (they ain't cheap)
http://www.pelicanparts.com/catalog/...pg5.htm#item17
Old January 13th 2008, 12:56
1303R's Avatar
i see there's a difference between pre and post 78 models. i have saw adjustable spring plates fitted and they 1 7/8" outer and 2" inner so prob no good to me, expensive too. wonder if i can replace the outer bush with a spherical bearing? maybe a bit harsh thou, but thats what most coilover conversions use.
Old January 13th 2008, 22:01
Yep, I told you they are not cheap. For a street car they would transfer alot of noise through the body, but some may not mind the extra noise.
You might get some info from this company;
http://www.goturethane.com/RunScript...&p=ASP\Pg1.asp
Looked at some other sites like prothane and energy suspension, but they don't list "air cooled" VW's.
Old January 17th 2008, 16:13
1303R's Avatar
well ordered up another set to go in. gonna see if i can cut a slice off of the old ones to pack it out a bit more to tighten it up. like an extra washer.
poo picture but can just make out the spring plate tube is rubbing on the torsion cover plate. both sides the same
Old January 18th 2008, 04:23
The best solution by far are these bearing ones, especially made for beetles:
The ones on the left.
Sold by gwd-weiser.de
Old January 18th 2008, 13:22
1303R's Avatar
just been on the gwd web site, and can't find any bits think they must be updating web site. would you know how much they are and if they ship to the uk?
Old January 18th 2008, 14:04
They are at the 'news' section, way down that page, but its not bothersome to scroll down there
They are about 250 euros IIRC. I am sure he speaks english, at least he did at EBI.
Old January 18th 2008, 17:25
1303R's Avatar
cheers, nothing in the products section. should ave looked about a bit more. 250 euros don't sound to bad, thanks for the input
Old March 5th 2008, 21:04
mccarthy500 mccarthy500 is offline
can the gwd torsion bearing be used with a 944 spring plate? and when converting to rear coilovers and getting rid of the torsion bars can this be used instead of a uniball system or a hiem joint?
Old March 6th 2008, 11:36
Good question (for Gerd?) as I would like to know that as well and particularly for the spring plates of the 944 alu trailing arms (if they are different).
Old March 7th 2008, 18:08
well if anyone has an answer to this question let me know please. -John
Old March 8th 2008, 19:25
Bug@5speed(US)'s Avatar
John
I have them but it won't be for a couple of weeks before I can let you know..
If you have the outside diameter of outboard side, then that would help.. as I have the parts down stairs in my basement some where.. and would spread things up..
Let me know and I will try to help
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old March 8th 2008, 19:48
cool i'm going to be working on my car today i will see if i can get a measurement
Old March 8th 2008, 22:36
Weather permitting I will also at my end..
I have a tent outside that my bug is in, and I am not sure if it will make it through the night
Wish me luck, its windy..
Alex Olaverri
Tele: 973 204-5463
