Old January 31st 2008, 20:35
dub_crazee's Avatar
Porsche 944 tech page....
on the tech page it described using a kerscher disc, and 944t caliper......but
kerscher disc it 20mm thick
944T front disc is 28mm thick
944T rear disc is 24mm thick
Or am i missing something?>
Old February 6th 2008, 17:54
dub_crazee's Avatar
38 views and no replies
Old February 13th 2008, 22:08
vdubfund's Avatar
vdubfund vdubfund is offline
Thumbs up 944N/A single pot calipers are needed
You will need to use the 944N/A calipers on the kersher discs, or Boxter 986 brembo rear calipers from 97~. As the rear boxter discs(2.5L)(97~04?? ) are also 20mm. Same with 944N/A. So you`ll have to radially mount the boxter caliper to the front spindle . Boxter discs 24mm up front and 20mm in the rear, so you`ll have to use rear calipers up front for the kersher setup. Same as 944 N/As.
If I`m mistaken , someone please let me know.
Old February 18th 2008, 05:59
dub_crazee's Avatar
yep i agree with the above, and have considered the boxster conversion (although CSP do a kit i was going to source the calipers seperatly) so the info on tech page is wrong?
