Old February 16th 2008, 11:05
redhot redhot is offline
Old vs new Super suspension
Tried a little search but no luck...
So: what is the big advantage swapping the early 3-bolt to the 2-bolt strut?
As far as I can read, VW did this to improve safety. Can anyone explain this issue a bit better? I think it is similiar to rolling a wheel with it leaning to the inside vs the outside = more stable
Are there any more issues? Clearance with larger wheels?
And lastly: are there any good kits to lower the 3 bolt design? Don`t need coilovers, looking for a about 50mm lowering. At what point do I need to change the shocks?
Old February 16th 2008, 17:36
Turbo Haraune2's Avatar
Turbo Haraune2 Turbo Haraune2 is offline
The 3 bolt spindles are the strongest, 2bolt tend to break around the lower balljoint.
2 bolt give you more tuning options
CSP has lowering springs to get your wanted 50mm
Old February 16th 2008, 17:46
Superman
Give a search over at SBO! for "negative roll radius" and you'll get the info you're seeking.
Old February 16th 2008, 19:41
I've had modified version of both.
The biggest disappointment with the 2 bolt is that you cant go as low as a 3 bolt car and on my 2 bolt car the nuts on the drag link touch lower control arm when negotiating something like steep driveway where the suspension goes through a large movement. I don't think that this would be a problem on a rack & pinion car.
I'm not sure how the negative roll radius is affected when running different offset wheels.
But I'm still very happy with way my 2 bolt car handles.
