Old February 21st 2008, 05:26
kafer9 kafer9 is offline
Hydraulic clutch
Has anyone used the saco hydraulic clutch kit,if so what are your thoughts about the quality and ease of fitting,or lack of it.Thanks.
Old February 21st 2008, 17:50
AIRSICK's Avatar
AIRSICK AIRSICK is offline
Hydro Clutch
I've got one on my 69. It worked good with my stock engine and clutch.
I've just spent the winter tearing down and installing a 1915 with a 1700lb clutch. I haven't got it running yet but I think it will work fine.
During the tear down I replaced the plastic tube that runs from the Master cyclendar to the slave cyclendar with a metal brake line (in the tunnel). I then atached a short section of -4an braided line from the master to the tube. This helps when you have to remove the master for some reason. You can pull the master out of the tunnel and then disconnect it.
Then I put another small piece of -4an braided line from the end of the metal line where it protrudes from the pan to the slave cycendar at the tranny. I also added a slave saver bracket to the trans for the slave to mount to. I got all this stuff from German Auto.
Old February 28th 2008, 11:23
hugovw1976's Avatar
hugovw1976 hugovw1976 is offline
I made my kit with a tilton master cylinder and CNC pull cylinder.
I install the master cylinder next to the brake cylinder, I weld a 3/16 plate to bolt the master cylinder and adapt to the pedal with a weld base. and work great with a 1700 lbs clutch.
VW 1976
Old February 28th 2008, 12:15
Turbo Haraune2's Avatar
Turbo Haraune2 Turbo Haraune2 is offline
nice setup Hugo!
Im doing just the same with the original subaru master that came with the front cut for the engine
Old February 28th 2008, 17:36
Very cleverly doen indeed Hugo! I really like your own creation.
Old February 28th 2008, 21:32
Very nice Hugo
