Old February 22nd 2008, 14:00
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Is the 228mm WBX /T4 flywheel forged?
Is the 228mm WBX or T4 flywheel cast or forged?
Has there been any issues with using these in high torque abuse environments?
Thanks for the assistance folks.
Old February 23rd 2008, 10:20
I have read that it is forged but have no proof. I am running one behind my 2.0T, soon to be a 2.4T
Old March 6th 2008, 14:26
1303R's Avatar
1303R 1303R is offline
i'm sure i read that the type4 228 is cast and the wasser is forged. i'm after a clutch that'll take 200bhp turbo to fit mine, really want a 6 paddle if anyone knows where i can buy one?
Old March 6th 2008, 15:21
DORIGTT's Avatar
I've got the Wasser 228 and would like to use it if it is forged.
Old March 6th 2008, 21:36
To check if it's forged or not one easy way is to use a drill bit. Find one of the spots that was drilled to balance it, and drill just enough to remove some material. Drill it slow and watch the material coming off. If it comes off in little greyish bits, its cast (like when you get a brake rotor or drum turned). If it curls up as its removed...its forged.
Old March 6th 2008, 23:06
Bad bug's Avatar
Bad bug Bad bug is offline
From what i understand all 228mm waterboxer was forged. I also have one to put on my 2.0ltr type 4 coupled to a 091 gearbox.
Old March 6th 2008, 23:14
There is also a T4 228mm "cast" flywheel 76-79 Bus.
Old March 7th 2008, 01:15
Bad bug's Avatar
Yes that 76- 79 i think is for the aircooled engine that was cast. Waterboxers are forged.
Old January 27th 2010, 08:03
Obiwan Obiwan is offline
For T4 aircooled engines, only the Porsche 914 2.0 215mm flywheel is forged.
