Old March 24th 2008, 12:55
fuzzybear1981 fuzzybear1981 is offline
fuel pump
Hi I have a new engine and need a fuel pump....the spec is as follows
- 2387cc
-New As41 (mag) case 94mm full flow stroker
- 86mm German forged C.W crank, chevy joournal nitrated and 8 Dowel 11/32 wedge matted
- 5.4 H beam rods chevy journal ARP bolts, German forged 14lb flywheel 11/32 8 dowel
- Norris racing lifter with web cam 86B, bugpack magnum straight cut gears with racer spacers
- 30mm oil pump modified for full flow with CSP billet ally pump cover, gene berg chromoly gland nut torqued to 800 ft lb
- Kennedy 2100lb pressure plate with Dankin racing disc, 94mm barrels and pistons
- 44 x 37.5 valve's with dual high rev spring chamber work with 55cc chromoly retainer and keepers
- Scat 1.4 ratio rockers 120'000 PS1 manton push rods
- Dual IDA 51.5 Jaycee carbs, gene berg linkage
- Mallory unilite distributor, BMD serpentine pulley system
- Mallory coil
- 55 amp bosch alternator, empi 3.5 qt deepsump
- Dog house oil cooler type 4 conversion
- 10.1:1 compression engine made 211hp @ 6000rpm with 193 lb of torque
- 1 3/4 merged ceramic coated header with stainless steel phat boy muffler
I was looking at a holley pump and i see there is a red and a blue......can anyone recommend which one is best??
Cheers
