Old December 12th 2002, 14:21
sdp65 sdp65 is offline
what am I doing wrong
I am trying to put my cylinders into the pistons and there is a little chamfer at the top of the cylinder that keeps catching the bottom oil ring spacer and no matter how tightly i fit the ring compressor into this chamfer, I can't get it to go in, have any of you had this and fixed this problem?
thanks
Scott
Old December 12th 2002, 15:35
Richie's Avatar
Richie Richie is offline
Are you trying to get your pistons in from the top? Try it from the bottom. I know there is a chamfer on the bottom, and that even helps with fitting the pistons. On the top of the cilinder is no real chamfer as far as I know. Anyway good luck and try not to break your rings! Hope to have helped you!
Cheers,
Richard
Old December 12th 2002, 15:55
kdanie kdanie is offline
I had a little trouble with my type 4 pistons/cylinders. Be sure your ring compressor is very tight and tap the top to ensure it is square, keep trying without forcing it or you will break your rings.
ken
